modessitt
1) Looks like your brightness is up too high (vector lines connecting different things).
2) Is your picture crooked? Yoke misadjusted?
3) use your PCB pots to get your image centered vertically and the proper width
4) I saw this problem recently when someone replaced a resistor in the deflection circuit with the wrong value. They had replaced R701 with a 1.3-ohm resistor instead of a 1.3k-ohm. As R701 is in a parallel circuit with the rest of the amplification circuit, and is connected to ground, then entire signal for that side of the screen was shunting to ground. Replaced it and it was fixed...
