Madaracs
WG6100: After LV2000 installation, voltage not right on Pin 3.
I just installed one of the LV2000 2.2 boards.
After applying power, LEDs on LV2000 both light up. All previous components completely removed (no leftover wires/posts/etc.)
I measured the voltages on Pin 6 and Pin 3 as stated by the instructions. I'm measuring the voltage on the + voltage side (at Pin3) as ~+35 volts. If I adjust it, it does go down but not even -1V.
The other side is working and adjustable. I've got it tuned to -26.04V
Is this a problem with the LV2000 or do I have to look elsewhere on my deflection board? (Or maybe somewhere else even?)
Hopefully someone else has seen a similar problem?
