WG4900 Yoke
SuperBee4406
greenville, South Carolina
I am installing a wg4900 chassis back into the frame. The problem is that I need to hook the yoke back to the chassis and I want to make sure I connect the wires correctly. This monitor will be used in a Spy Hunter. Anybody out there know the correct connection of these four wires?
Red and blue are spaced farther apart than the rest of them:
Red, Blue, Green, Yellow.
Monitor inserted with the chassis to the right side when looking from the back.
If you're worried about it, hook it up before sticking the monitor in to make sure it is right....
I guess that is why the monitor didn't work.
So I need to find a G07 chassis?
or a 4900 yoke. be aware that there are two versions of the 4900 yoke (with 4 yoke numbers between them). Putting the wrong yoke with the wrong version of the 4900 will give you a vertical issue that can't be adjusted out...
