WG4900 wtf?
AaronCal
Independence, Missouri
I just capped a 4900 and all of the caps are on their correct polarity I double checked. I plugged it back in and now the monitor won't turn on. I hear a pop but there's nothing on the screen. I don't know what's going on. Can anyone help with this?
it looks like a pin fell out of the neck. It's the first pin going counter clockwise. Is that the problem? Is there any way to fix that?
did you re connect the flyback anode wire?
did you reconnect t the yoke?
did you reconnect the power?
did you reconnect the signal wire set?
did you reconnect the defusing coil?
just trying to help
1) verify you have power to the chassis
2) verify the fuse is good.
3) measure the B+ and report back...
