WG4900 Red Shadowing effect
SuperBee4406
greenville, South Carolina
I have a WG4900 in my MS Pacman, and I decided to rejuv the tube since the picture was blurry and I couln't adjust it out. Well I went through the montions of the rejuv, put it all back together, and now its time to make the color adjustment. The picture did improve with the rejuv, but I can't for the life of me get this red shadowing effect to go away. Everything that has red in it gets this red shadow that goes off to the right and down. Even with the red all the way down its still there. Tried all the pots on the neck board, I have tried turning down the black level, and brightness, can't get rid of it. Convergence is off a little to the left.
Possible bad tube? I did hit the "Remove Shorts" on my BK470.
You have two red pots. Have you tried turning them BOTH down all the way. if you still have pink in your maze, then I'd check your pots. The red SHOULD go completely away if they are both turned all the way down...
