WG4900 How do I flip it?
radioflyer
Clarendon, Pennsylvania
Been working on Kung Fu Master the last week, and decided to swap out monitors. Thats the easy part. Now, the little suction cup for the flyback on the tube is at the bottom, and not on top where it should be. What do I do to get it back on top of the monitor again?
Since I am half awake, I can't remember what I have to change....need coffee!
monitor
Have not seen that in awhile. Remove anode(rubber boot), neck board,ground wire and deguazing coil plug.
remove 4 bolts in front and gently remove tube and turn it around so anode hole is on top. Hook everything back up.
Or just cut the yoke connector between the blue and (green or yellow) connector. Then swap the blue / red around and the green/yellow around. This will electronically flip the image 180.
