WG4602 Pinout question
SuperBee4406
greenville, South Carolina
I can not find the pinout for this daughter card out of my WG4602. When I do find info its for the board with 6pin/3pin setup, not this 5pin setup. The third pin is not broken there is no trace going to it. Anyone out there have info on this board. And can I just buy a 6pin/3pin board and use that instead of this board?
Your board is a "P302" version video interface card from the Wells-Gardner K4600 series monitor. It accepts composite negative sync only.
I made a list of the pinouts of the various video interface cards several years ago and they are posted here:
http://www.ionpool.net/arcade/tech/19K4600_pinout.txt
I am using this WG4602 in a Defender cab, and trying to hook a Jrok board. With this card I can't get the game to sync up. Can I install a different board with the correct pinout?
I don't know what a jrok board is. Does it output composite negative sync? If so, then you can use your existing video interface cards.
FYI, ALL of the Wells-Gardner K4600 series video interface cards are interchangeable. It's just that some have different features than other. Some cards are setup for certain syncs:
Composite negative sync only
Seperate positive sync only
Seperate or composite, positive or negative sync (these are the most desirable cards)
Its a MultiWilliams board:
http://www.jrok.com/hardware/wsf/
Defender uses + sync, and the JROK board is Jamma using neg comp sync.
Hey guys, just found this post and wanted to see if you could help me ID which daughter board I have on my 4600 monitor. The label states it is a Model 4613.
Need to see the silkscreened numbers on the foil side of the board, but you might have a P306 card.
So your list indicates that I should have a total of 9 input leads from my board. However, I only have five (R,B,G, Grnd & Video Sync) coming off my JAMMA harness. I hooked up the R,B,G & Grnd as indicated and the VSync on pin #3 of 204 as suggested by one of my friends. All I get on the monitor is a compacted white screen. What am I doing wrong?
Thanks again for all of your help. I saw that the JAMMA harness from the cab that I took the monitor out of had that jumper wire, so I tried that as well. As of last night, I was still getting a white screen which was pinched horizontally. The only idea that I have come up with so far is that maybe I swapped the VSync and ground wires. Does this make any sense? Is there anything else that I should be looking at?
So I hooked everything up as directed and still only get a white screen that is slightly cut on both longitudinal sides. No picture, no color, nothing. Attached are some pics of the wire setup. Any ideas what I am doing wrong or where else I should be looking for issues?
Can you trace the wires back to the Jamma harness? It looks like you have a solid white wire that should go to the Jamma Sync position and a white with black stripe that should go to the ground.
You should also try a different Jamma board if you have one and report the results.
Oryk, the white/black wire was traced back to the Video ground on the JAMMA harness and the solid white to the VSinc on the harness. The board works fine in my JAMMA NEO GEO Cab. Someone suggested that they should be a second ground for the Vsinc. Is this true?
There is a second place for ground but it is rarely used. It is the first pin on the set of three pins. If you look at the pic you put in post #11 you'll see that both the ground you have connected and the ground you haven't connected are tied together. There is no need to connect another ground wire.
Do you have another Jamma board that you can put in this cab temporarily?
With a solid white screen you are receiving all colors in all places. I have only seen this unexpectedly when the screen pot on the flyback was turned all of the way up.
