I just recently capped a wg4600 and am using it in a cab with a 48 in 1 pcb. The picture looks good, but I can't seem to get it "centered". If I adjust the pots to fill the screen, then the right side is cut off. If I back off the adjustments so that the right side (of the vertically mounted monitor) is visible, then there is about a 1" space on the left side. Is there some way to adjust the vertical position on a wg4600?
