WG4600 B+ pot replacement
security0001
Donor 6 years: 2020-2025
Montana
i am wondering what the proper direct replacement for the B+ pot is?? the manual only give a part number and no discription for it and i was told a P1107 from bob roberts would work. is that correct or is there a better solution. thanks
The 4600 doesn't have a B+ adjustment pot. Which pot are you referring to?
VR501 in the manual is said to adjust the voltage. the manual only shows a part number for it, but no discription.
i would feel better replacing it because it is glued down and the B+ is suppose to be 127vdc and mine is at 134.8vdc. i was told the P1107 from BR which is a 1K, but there was no confidence from the person telling me that would work.
P1107
Type F
1K
P1107
Type F
1K
if that person wasnt bob then email him, he will know for sure.
