Deadpool66
I have a k7000 monitor with no picture. The chassis looks clean, Looking for suggestions on where to start.
Is this from your 6 player X-Men? I think the flyback nobs on mine were originally black, but I replaced them anyway. I was just wondering in terms of when WG might have stopped using those white knob flybacks.I haven't attempted to turn it on since the first test. The knobs are white on the flyback btw I'm hoping for an easy fix.
i have to say this is the best monitor that wells has ever put out. In my experience the flyback rarely went out and i fixed 1000's of these. Of course these are getting older and they are going to fail eventually. White knobs/black knobs? never had any real problem with either flybacks.
If you need one i have one that i have been testing for a few days.
I don't replace the flybacks on them unless they are showing cracks or improper function. or if the customer requests it...
what else would charbroil the traces of the side of the flyback circuit going to C36?
I cut the old one off, soldered it onto the new fly, and sealed it with heatshrink tubing.Now I need to know what tools are needed to add the pin connector to the wire on the fly that connects to the neck board.
Im also wondering if i should replace the voltage regulator the bob roberts kit didnt include one but i keep reading about it in other repair posts.
If the VR is bad, it will blow the fuse, so go ahead and fire it up.
I'm gonna bet it won't work, due to some solder issue. If it doesn't, measure the B+...
