Wg u2000
Raiden_2112
Dallas, Texas
I have a U2000 that is giving me some problems.First of all it is not switchable for medium and standard res.I was told it was a standard.It shows 9 pictures when hooked up to a standard res and 5 when hooked up to a medium res, the fly back wines, I have not given a cap kit yet.ANy and all information is greatly appreciated.
Well, a U2000 is definitely a standard-res. I can't verify that is what you have from your pic, but there should be a sticker near the video input pins that says WG2520 if it is a U2000.
Sync should be connected to both the horizontal and vertical pins, I believe, so make sure it is. If it's a JAMMA game, then they should be connected to the negative pins.
Does adjusting the horizontal hold do anything? Is the B+ okay? Has the monitor been recapped yet?
Has not goten a cap kit yet, its in a neo geo 2 slot.Yep its a u2000.Will check B+, Horizontil hold is allready focused in the picture is staying still.
It just might LOOK still because the scanning is so perfect that the image appears to not move.
Double check that the board you're using doesn't have a freq adjustment, too...
