This POS is really pissing me off!! Ok, Changed out the U701 chip, still nothng. I turned the B+ to 127v per the WG site, still nothing. My voltage at TP 203 have like 1.2 volts. The voltage at pin 10 on U701 is like 8.5 volts. What else now??? I have a few quarter sticks!!!
The Z702 Needs to be atleast 12v's
You need the Horizontal output circuit working to get any voltage from TP203
You already replaced the fly,caps,the zener,Q708,R760,U701
Did you get C712 in correctly? 1000uf 16v's
Any voltages on Q703 or Q704?
are the HV caps good next to the fly?
I would have pulled the whole crt and chassis in 20 minutes
and brought it to the shop fixed it then test it,first.
Not every monitor just needs a cap kit..
Using the schematic?, any open traces,did you solder the Horiz driver Transformer?
Its not always the same parts each time,you have to find the bad ones.
It's ok to have 120 or 127 when you checking the HOT circuit,you will still have a raster
if the Horiz Output circuit is working.
Is your yoke connected?
Good Luck!
