WG Out of Range message - Solution??
rainman154
Buffalo, Minnesota
I just got a new WG 19". It has the VGA male connector on the back. I hooked it up to my 60 in 1 iCade and got this message...
OUT OF RANGE
Hf: 28Khz - 70Khz
Vf: 40Hz - 150Hz
60Hz / 15.6KHz
I have NO idea what this means. The music for the game comes through the speaker, but this message just flashes on the screen.
Any ideas?
I am not familiar with this monitor but it looks to me like the monitor is currently trying to read 15.6Khz and you have the monitor plugged into the HF connector on the game board. Can you adjust the monitor to look for a high res image?
Dip switch on the PCB
Dip switch 3, dip number 2, should be ON
If it's OFF, the PCB is outputting CGA butyou need VGA for that monitor which is dip switch 2 ON
I thought I mentioned that in a previous PM... maybe not.
It worked! Beautiful!!! First time I have gotten to see the screen.
Now I am off to make sure I have the CP wired correctly. Thanks all!
