WG Monitor wont light up.
thefader
South Dakota
I have a 4 Player Wrestlefest cabinet that the monitor wasnt working in. I had a friend test the chassis, he replaced a few bad caps.said it worked perfect in his cabinet. I put it back in mine, nothing. I checked the voltage going to the monitor, 124v. Is there something else I could check, any simple things I could be doing wrong? There is a switch on the top of the machine, then a white push button that turns the cab on. These are acting a little iffy. Thanks.
plug the chassis back in, and test the monitors voltage under load. you can do this by sneaking your dmm leads in behind the connector where the wire meets the plastic connector housing.
