I just got a new never used early midway touch screen game. The game is setup for 230v 50hz power, Upon me checking the main power supply for the game it is designed to run on both 50/60hz without any issues. I do also have a proper 115volt plug for the machine since the original was made for use in spain
However I am wanting to make sure that the monitor chassis is also designed to run on both 50/60hz power at 115v, I have all of the original manuals as well, I see in the manual it shows on the monitor chassis, that there is a adjustment pot that shows 50/60hz (VR9). I wanted to see if anyone might know if I need to adjust that before I power up the machine, since I do not want to damage anything. I figured though since the main power supply was already setup to run on 60hz 115 that the monitor chassis would probably be the same.
Any help is appreciated
