WG K7613 neck board cap...
DP Louie
Visalia, California
I'm going to recap the WG 19K7613 that's in my Playchoice cab today. I ordered a cap kit from Bob Roberts awhile back, it's the correct kit according to his site (it's for the K7000 series). All the caps look correct, but there is one, a 4.7uf 250v for C204 that the map says is found on some neck boards. There is a cap at C204 on my neckboard, but it is a disc type, marked 103K YSP, and I don't see any indication of polarity on the board. Should I replace it, or leave it?
I usually replace it, but you can leave it if you have no problems after the rest of the rebuild.
As for polarity, you'll notice on the back of the neckboard that one lead is connected to the ground trace. That's the negative polarity...
Thanks Mod! I just finished the chassis, so I'll put it all back together and see... It will be easy to do that one cap on the neckboard even with the cab all assembled, if I need to. Thanks again.
