mfrohs
I have an A48ABK05X that from what I can find uses a WG K7600? I can't get in there to see any numbers on the board for now, but that's what I found on google. It's from a Cyberball cabinet dual monitor cabinet if that helps at all.
The right monitor is arcing out of the flyback, and I don't know enough about this stuff to take any steps on my own yet. It sounds like I'm going to need the K7000 flyback repair kit from TheRealBobRoberts. Could someone please verify that and add anything else I might need?
I tried adding a ground strap to the monitor because the right one didn't have one hooked up, but the arcing continued. The left monitor does have the ground strap and is working fine. Could it have something to do with the power supply, or is the arcing out of the flyback a pretty black and white issue?
Thanks!
Thanks!
