Wg k7500
Nixs
Sherman, Illinois
i have a couple of these with the flat line across
what part needs replaced is it the hot ?
haven't fixed any in a long time and i know it was a easy fix
thanks!!!!
Horizontal line when mounted horizontally? That's vertical collapse and is caused by either bad caps, U601 shorted, R303 open, D302 shorted, or any combination thereof. It could also be a broken V-POS or V-SIZE pot on the remote.
Vertical line when mounted horizontally? That's horizontal collapse and isn't seen much, but is caused by bad solder or a broken trace, probably around the width coil...
