arcanescroll
Just curious if I could convert my WG K7500 to standard res using a Wei Ya universal replacement chassis? Anyone tried this?
I have 3 Wei Ya chassis sitting in the parts pile. All three
lasted about 20 minutes then smoked.
Never again.
JD
Where are you located? I will trade you a working standard res 25" K7000 for your 25" K7500. (Assuming the K7500 works). PM me to follow up on this.
Or find someone locally willing to do this.
Medium res monitors are hard to find and some of us want to play house of the dead.![]()
I'm in Burnsville, MN, but I would need a 27" to fit the cabinet. Thanks anyway.
the guy that did the gig that I have now would 86 ALL chassis and put these garbage Wei Ya chassis in the games. He tossed 100's of k4900, G07's and k7000's before I got the job.
Talk about a nightmare. Bouncy, non brightness stable crappy chassis.
the entire thing. fucking hacks.
Wei-Yas are complete junk.
Wei-ya is a legit monitor manufacturer and not Chinese and to the best of my knowledge they don't make "universal" chassis. I wish the OP had posted a link to the chassis but if it's the one I think (no switch mode power supply and very few components) it's not made by Wei-ya.
I think Makvision IS Wei-Ya. and based on that alone, they can suck it.
my rule is if it only has 2 wires, chances are it needs an iso. the ones intended to plug into walls will have the ground wire built into the plug too. the Makvision stuff doesn't if I remember right though, so that's a key difference.
