JTarcade
OK, in a moment of weakness I bought a SFRush the Rock arcade with a bad Neotec NT-27E monitor. It also came with a non-working WG K7500 monitor. Turns out someone had installed the wrong CRT in the NT-27E - it has a Neotec 2701 bonded neck CRT which is bad news for the NT-27E HOT transistor.
Soooo, my attention has now turned to the WG K7500 monitor which looks like it will fit physically, but I'm not sure if it will fit electrically. The same genius that put the wrong tube in the Neotec has also given the WG some love, so it is missing the remote adjustment board/harness, and the video signal harness (they just lopped it off at the monitor board). If I make a harness to connect the WG to the SFRush video connector, are they compatible? Any advice is appreciated, except for: "don't buy arcades with bad monitors"!
John
John
