WG K6100 - No picture... Raster Sound... Question
rainman154
Buffalo, Minnesota
I picked up a WG 6100. When plugged in, I can hear raster sound, and the game does play blind. But nothing comes on the screen. No spot killer.
Also the red light on the board does not come on.
Is it the Flyback that is gone???
Any suggestions?
Any suggestions?
When you write "the red light on the board does not come on"... you mean the light on the monitor deflection PCB.. correct?
(this would be the same thing as 'no spot killer'... light off=no spot killer, light on=spot killer)
The redundancy night confuse someone (me), that's why I am asking.
The light on the game PCB IS on, yes?
So, to restate, with the game on:
Game PCB has a light illuminated
Monitor deflection PCB does NOT have a light illuminated
Monitor intensity has been increased
you can hear the deflection 'chatter'
the game can be coined (or it's on free play) and the player 1 and/or 2 start buttons are flashing
There is no image at all on the display
Did you try to turn up the screen on the flyback? I know its simple but if it was forgotten could be the issue!
The red light on the monitor deflection PCB (spotkiller) should come on at power up then go off. If it doesn't, check your fuses - on the monitor and at the power brick. Also, check the LV section (100's) for any burnt parts...
