frogger Active member Joined Feb 5, 2007 Messages 906 Reaction score 150 Location Ashland, Oregon May 1, 2017 #1 Can a WG K4900 chassis without the blue vertical pot be replaced with a chassis with the blue v position pot? Attachments 20170501_102338.jpg 513.9 KB · Views: 22 20170501_102351.jpg 533.9 KB · Views: 21
KenLayton In Memoriam Joined Dec 14, 2003 Messages 20,220 Reaction score 712 Location Olympia, Washington May 1, 2017 #2 Check out this service bulletin regarding mixing/matching the 4900 chassis between versions: https://docs.google.com/viewer?a=v&...FpbnxtdHBhY2lmaWNvfGd4OjM4NzYxZGQzMTNjYTg5NjY Mixing the wrong version chassis with the wrong yoke will result in a vertical "foldover" problem that cannot be corrected. I believe since yours has a vertical dampening pot on the chassis that you can swap with the vertical position pot style chassis. Last edited: May 1, 2017
OP OP frogger Active member Joined Feb 5, 2007 Messages 906 Reaction score 150 Location Ashland, Oregon May 1, 2017 #3 Thanks I will try to swap vertical dampening pot on the chassis with the vertical position pot style chassis. Since the one with the blue vertical position pot is damaged beyond repair.
Buffett Well-known member Donor 2012-2013 VAPS Joined Mar 12, 2010 Messages 10,991 Reaction score 263 Location Manassas va, Virginia May 1, 2017 #4 you also many have to do trace mod work. look the entire area over real good before you start. Peace Buffett
