WG K4900 Neckboard
Cliffo
Donor 2016
BC, Canada
Does anyone know if I can swap a 2061459-024 Neckboard with a 2061459-019? Is the difference the tube size as it would seem to suggest by the last 3 digits of the part #?
I'm trying to help a fellow KLOV'r out with a neckboard replacement, his is the 024, all my 4900's have the 019 boards...
Any ideas?
Is his tube bigger? 4900's often gave different ending designators for different versions of the chassis, not always for different sized tubes. In fact, if it was a bigger tube, it would be a 5500, not a 4900.
If they are both 19", then it should be fine. But you both should check the number screened on the bottom of your main chassis to make sure it doesn't end in -023. If so, matching one from a -023 to one that isn't MIGHT cause a problem, as the -023 needed a specific yoke that is different than the others, and I don't know if that difference requirement is due to the neckboard or not...
