mecha
a higher value than 154 lol it's been a long time since I've changed a width capOh, ok so that glob on the corner is actually a pad thats supposed to be there? So weird they would do it that way through a huge hole and not just a normal pin.... On mine, the wire that attaches to the ground was just wrapped around a bare wire on the tube. Is there a better way to add it like with a plug end? Or is that jsut how it goes?
And Im probably just gonna do a cap kit on this and also replace C365, but what do I replace it with?
if you go on this page you'll see different values in action on a Moon Patrol (where the displayed image appears almost like a perfect square on an unmodified monitor)
strangely parism didn't have a 390 nF example, that's the stock value the K4900 would have come with. yours would match the 150 nF example in the pictures. I would thus try a 390 (or maybe it's 394) and that should tighten the picture up more. I have an APAR width cap kit at work that I can look at the sheet and maybe shed more light on the situation.
