WG - Identification for MS Pac/ galaga reunion cabaret
kjoel
bayshore, New York
My monitor is missing RED color. Hence I am trying to figure out what monitor it is. If I cannot find a manual I will just replace the transistor on the neck board for RED 1st then go from there. States --> WG6062390 on frame
The monitor is a wells gardner for a ms pac/ galaga reunion cabaret (dedicated black cab with ms pac art on one side and galaga on other)
I have attached pics
thanks guys
lol, I got confused, cause the uprights came with K7400s. then I saw it was a cabaret.
I would check the red drive transistor first for cold solder (it might happen), and do the big resistor that's inline with it. while you're at it, just reflow everything. if you want to make sure it's the transistor, do the swap method, pull a known working good color transistor (green and blue, I'm assuming are good) and put it in red's place.
do you have red and not the green or blue? you might even get lucky and they'll all work from redoing the solder joints. :p
then of course if you're still missing red, then you have a tube issue. OR check the input header and/or the red signal wire in the JAMMA harness.
good luck
All harness wiring looks factory fresh. Game is like brand new. Cleanest cab I have ever seen. I will replace the transistor and take it from there.
Thanks again guys
Did you at last check it to see if it was bad? Swap it with the blue one and see if the problem moves to the blue...
