WG D9200 / Cap symbol question
Encom
Etters, Pennsylvania
I'm working on a WGD9200 that the screen is slowly shaking back and forth. I found C807 and C808 look bad, the cases are bubbled up.
When I go to replace the caps I notice that the symbol printed on the board for the caps is different from the rest of the caps on the board. It's like a normal cap symbol but there are diagonal lines between the two plates. I've never run into this particular symbol on a schematic before. Do the caps need to be anything special? (they are 470 uF 250V electrolytics).
Rich
Those are filter caps. The case look bubbled because the have a plastic coating, not because they are bad. In fact, it's rare that they will go bad, but you can replace them if you want (but they're not cheap like other caps).
And they're just normal caps. Here's the entire list if you need it:
http://forums.arcade-museum.com/showpost.php?p=1131876&postcount=4
