WG D9200 AC Input Connector 5 Pin WG shows 3 ???
Mikebetz42
California
The Chassis I have has a 5 pin AC connector... the Layout sheet from WG has a 3 Pin connector..... I am missing the connector and need to make a new one.
AC Input is in the lower left corner... the pic is of another D9200 that was for sale on the forums... so I know I am not the only one with this....
Does anyone know the pinout so I do not have to pull the chassis?
http://www.wellsgardner.com/pdf/Board/D9204_D9205_Board.pdf
Thanks,
-Mike
That is my 9200 pic. The power connector has 5 pins, true. Look at the bottom to see which are the two power traces, and connect your power wires to those pins...
I had a PM that said:
pin 1 white(neutral) left
pin 2 empty
pin 3 ground(green) middle
pin 4 empty
pin 5 black(line) right
Can anyone verify this? This monitor is in a RUSH 2049 cab I picked up. The monitor was said to be working...
Thank you,
-Mike
That's probably right, but I don't have a cab to look at right now. Like I said, check the bottom of the chassis for where the traces go, and that will tell you how to hook it up...
That would require pulling the monitor our of the cab..... something I am trying to avoid.....
It sits on a shelf, and has to be pulled out the front. Very little room in the back to work with on this.
Thanks,
-Mike
pin 2 empty
pin 4 empty
You can meter the center pin to see if it is truly ground compared to what is depicted in this diagram. (is there continuity between the center pin and the screw mount ?)
ac
A.C. goes to 1st and 5 pin. 3 pin is earth ground.
