WG Chasis swap
Seifer13
Ames, Iowa
I just bought refurbished K7000 chasis and found out my tube was bad. I have a big blue with a K9000 in it but the tubes are the same size. Can I use the 7000? Also Im assuming its a 9000 because the serial number is in the 9000s. Not sure how to read these.
Pics would be really helpful. I'm still not quite sure what you are trying do.
Do you have a Big Blue with a bad tube?
Bought a K7000 25" monitor and it's got a bad tube?
Huh? I'm confused.
I have a neo geo with a 25" K7000 that has a bad tube but the chasis is good. The chasis in my big blue is bad and has the same size monitor and uses a wells gardner chasis also. Can I put the K7000 in my big blue?
Oh, thank you, that's much clearer. Yes, as long as the tubes both have the same number of pins, yes, you should be able to swap chassis' no problem.
You need to make sure the yokes match as well. WG released a few different 25" monitors (K7000, 5500, U2000, U5000, and a few others). Mismatched yokes can be damaged. Also, if you don't have an iso but need one then you can burn up your K7000 board very quickly.
