WG 7401 dead
MacPac80
I have a 2004 Wells Gardner 7401 monitor that appears to be dead. It was used only at home with an Arcade Legends machine so it really didn't see much use. No burn in on the screen even. Anyway, I recapped it and still nothing. I can hear the dagauss coil kick on and a faint click...click...click...noise and that's it. Any suggestions?
thanks,
Mark
If you hear "click click click", then check to see if the HOT is shorted. Black lead on center pin, red lead on each of the outer pins. If you get a short, pull it and test again...
I had a 7401 doing the same thing. Turned out to be a shorted C121. It's a .1uf disc capacitor.
