gozer5454
Volunteer: Google SketchUp Guru
New chassis just arrived for my 27" 7400. Works good. Question is: what is the little Pincushion board on the chassis for? It seems to work with or without it on. If it is not necessary, then why make it?
Sometimes you'll find that the corners of the picture are slightly bowed out or in. When this happens, adjusting the pots on the pincushion board will help straighten it out. Without it, it'll still work, but you won't be able to adjust it if you have a problem.
The board was an optional add-on...
hey, what does this pincushion adjustment pcb look like? i think i could probably use one for my 7401 at it does bow in horizontally.
