WG 7300 with color problems
MC35
Friendship, Wisconsin
I think I have seen this before but not sure what fixed it. This is a WG 7300 (providing I identified it right) and it may be hard to see from the picture but the bottom left of the screen is "washed out" This is vertically mounted. It looked awesome when I bought it and it was mounted horizontally, but it doesn't seem to like being mounted vertically. This is a 60-in-1 not a ms. pacman. Any ideas?
that is a degauss problem.
turn your game on and off every 30 minuets for a couple hours to let the auto degauss on the chassis try and get rid of it.
or use an AC drill or soldering gun to manually degauss it.
Peace
Buffett
Peace
Buffett
How do you use an AC drill or soldering gun to degauss it?
Tried the drill, and it affected it, but it went back to the original problem. I put in a new Degauss coil from another monitor and no change. When I bought the monitor it looked awesome. I'm wondering if mounting this vertically changed some of the electronic interference, because now some of the wires going to the neck are located differently.
Any suggestions?
turn the cab 90* and try it again.
if that does not work move it to a new location and try it again.
Peace
Buffett
Cab is in a new location and problem still exists. I have not installed a cap kit yet, would it help this problem?
it could be. but i do not think so.
maybe someone has a rel degassing coil and you can try that.
also look to see if there is anything magnetic stuck to the frame or inside the cab near that area.
Peace
Buffett
