gatordad
wg 6100 HV R910 replacement resistor value different than factory is this ok?
Hope some one with more experience than me can chime in here
I'm pretty clueless about resistor values and acceptable substitutions.
First question first
You can drop resistors in any way correct? I mean there is not a positive and negative side, like caps is there?
Second question
I have a small discrepancy between values listed and what I received and I want to make sure it is an acceptable part exchange
I am doing a BR Deluxe kit cap job on this wg6100, I'm done with the deflection board and now onto the HV section.
My question is
R910
Bob lists the part for R910 as a 6.8k 1/4w resistor
but the wg parts list in the manual lists it as a 12k 1/4w resistor
Is this an acceptable swap?
Thanks in advance
Second question
My question is
R910
Thanks in advance
