WG 4961 won,t center
anthonystich
Hellertown, Pennsylvania
I have a WG4961 that had a bad picture ,I just finished a recap kit from Bob Roberts ,Everything looks clear and bright but the left side has about 4 lines running up and down and the picture is shifted left, I tried every knob and jumper but can't get it center or the lines to go away , am I missing something ?? Please Help!!
I have run into this issue as well.
Unfortunately I just adjusted the picture to the side of the screen to eliminate the lines, and it played pretty well anyway. Just not perfect.
Your VERT DAMPING pot should make the lines go away. Your RASTER POSITION adjustments should make your pic center move closer to center...
left side fold over ,about 1" 0ff
I tried everything ,still cannot shift the image to the right,and the left side of screen looks folded over, I tried different Jamma Boards ,same result. Still Lost????
