I have a WG 4901 that mostly works. I got it from a guy who said it worked fine before he did a cap kit. I know this guy to be a good person and have no reason to doubt him. I have double checked the caps to be all the correct values and positioned correctly. I don't see any cracked/bad solder joints. Could it be a bad cap somewhere? Should I just to a new cap kit just to double check? The only problem seems to be on the left side, mostly in the upper corner where the 3 colors don't converge correctly.
