wg 4900 worked, but ng with 60-1
r5g
Nevada
have a wg 4900 that worked well with ms pac, but trying to convert to 60-1 the pic is horrid and wont adjust out, sync is bad, colors suck, lop sided, ect
will a 60-1 boared even work with this monitor or is it to old
4900
They work pretty well with 4900s actually. I have had good luck using them with multies. The pinout is different than a GO7. Might check that.
If your sync wiring has the vertical sync connected, disconnect it...
