wg 4900 transplant replacing wg 4500.
jrich3031
Milton, West Virginia
So, recapped and everything is golden with the newly transplanted 4900 in place of the original 4500 that came in my Galaxian upright. The 4500 had 5 wires feed from the PCB. the 4900 has around 9. 3 on one con. and 5-6 on the other. I know red to red, green to green and blue to blue. what about the neg sync? does this 4900 REQUIRE more than the Galaxian harness provides? how do I turn 5 into 9?
you will need a second connector to hook up your neg sync, sync is the last pin on the k4900, if galaxian is neg composite, cant remeber off hand. post a pic of what ya working with.
4500-4900 swap pics
here you go. like I said, this new 4900 is installed. powers up with neck glow. all new caps and ready to play. just a connector away from hours of Galaxian bliss....
the connector in my hand is the original Galaxian harness plug for the 4500 monitor that is now in a dumpster. the last pic is the ultra useful drawing of the pinout for the new 4900.
sorted out
Ok, I found a Galaxian schematic, that I could actually read when you enlarge it, and mapped the wire colors to the functions. I compared this info to the wg4900 manual and all is now good. All the other sync pins on the chassis are not used. thanks for the help guys.
Asteroids, Pac Man, Defender, Pole Position, Gorf, Arkanoid and Galaxian
