WG 4900 question..width coil????? Huh?
radioflyer
Clarendon, Pennsylvania
Was finishing up the 4900 switch in Kung Fu Master, when I actually READ the tags and labels on the metal frame....seems there is this width coil thingy....wrapped in wire.
Educate me people..what the hell does that do? Is it adjustable? Screw inside it or something?
Its the tall white thing, usually near the flyback. Its an adjustable coil that controls the width of the picture. That said - don't adjust it with a metal tool!! It needs to be adjusted with a plastic adjuster tool.
Thanks guys.
While I'm at it, is there any other way to widen it out without screwing around with that coil? That little puppy makes me nervous for some reason....
4900 wells
You can adjust the width coil but you might have a mylar cap in the horz. section that needs to be replace as i have seen that dozens of times on that model.
