WG 4900 in a Mario Bros
joseph77
Cicero, New York
Is it possible to put a WG4900 in a Mario Bros? I have the inverter board from Mike's. Will I need to get the power supply conversion kit?
You'll need some way to get an isolated 120 for the monitor. If you have the inverter, then you probably got the one with the amplifier, too?
You could just put an iso in and run 120 through it for the monitor power...
Yes, it is the one with the amp. I'm guessing the clean way to do this is to get the ps conversion kit and install the proper iso, if I remember correctly the nintendo iso does not run 120, correct?
You can use the Nintendo iso if it is there, and it will work just fine. My Nintendo test rig uses a 100vac iso, and I power G07's and 4900's without issue.
