Hopefully someone can help me.
My WG 4606 in my Ms Pac CT, was working but needed to be capped, per the pervious owner. Like I said, it worked, but had lines and not vibrant colors and so on.
I capped it, checked my work to make sure all neg leads on the caps were the way they should and same for the positives.
I hit all male and female connector pins with new solder. Any other joints that looked suspecious also got new solder. Male pins cleaned off. New white insulator stuff on both metal transistors.
It all looked good, turn it on, the game plays blind and I get this:
Neck glow.
All resistors are hot (verified with my infarred thermometer) on boards that have them.
All transistors are hot on boards that have them.
No pic at all! Nothing!
Is there some adjustment that needs to be done after a cap kit on this thing?
Game plays blind and I got no pops, or smoke when I powered it up, that's a good sign.
I did a search on "plays blind" and "Pac Man". Most issues were corrected with cap kits, others never said what corrected the issue. Thanks,
Neck glow.
