picked up a stargate cabinet that had a monitor no chassis. the tube is a 19VJTP22, 10 pin
is there a way to check to see it the tube is worth saving minor burn but other than that looks ok. I have check what the impedances are on the vert/hort would thta tell me if it is good?
I also found that the WG 19K4900 series has the same tube is the yoke different for the
4600 series and the 4900 series
I don't want to pick up a chassis to test it because will not have a use for it if it don't work
any ideas send it my way
thanks
thanks
