WG 4600 H size?
killapimp
Woodstock, Illinois
How do you adjust the H size on a WG 4600? I looked at the manual, and there is a H size coil, but it doesn't look like you can adjust it in any way. There is about a two in. gap top and bottom, and the picture is smaller then the pacman burn in on the screen.
The width coil is right next to the chassis and has two brown wires soldered to it. You adjust it with the common PLASTIC "hex alignment tool".
