WG 25k7193 problems
INOVERMYHEAD
Ohio
I have a WG k7000, monitor, had wavy lines on it side to side, you could kinda see the writing on the screen and a little bit of the picture, almost like the picture has shifted half way across screen, and the left is on the right and the right is on the left if that makes sence. . .. any way, just got a repair kit from bob r. and replaced the hot, flyback and a cap kit, still have the same problem, any ideas???
For what it's worth I had simliar problems where it didn't look like the sync was right, and upon closer inspection I found one or two cracked pots on the remote board. A new set and it was good to go!
Also with Neo Geo cabs Bob adds a tantulum cap (looks like a chicklet) thats not documented in his instructions that may need swapping.
What game is it hooked up to? if it's a JAMMA game, make sure the sync is connected to the negative horizontal pin only (the last one)...
