WG 25K7191 C38 question
debaser138
Grand Rapids, Michigan
I'm working on WG 25K7191 chassis that had a blown flyback, blown fuse and shorted HOT. I did a cap kit, replaced the flyback, HOT and fuse. I tested IC4 and there were no shorts so I think that's good. I was seeing a short across C38 so I pulled it and it's definitely shorted.
The poly cap is blue and labeled as .39J PD200V and it's 2 legs. On the solder side of the board there is another poly cap that connects to one leg of C38. That poly cap is brown and labeled 3626H 1.6KV.
Where can I get a replacement for C38? Thanks!
i also stock all the poly caps for the K7000 and many other chassis.
test the other cap to be sure it is not shorted.
Peace
Buffett
C36 looks to be good. This flyback went out hard and burnt a hole in the board from the leg of the flyback that runs to the yoke connector. I had to run a jumper wire to fix that as that big trace was burnt up.
Thanks for the info guys.
