DanV
Exactly. I usually just solder on the back. But for testing what you can do it just wrap a copper wire around both pins before you put the plug on. If it works then you can solder in a jumper.
I've had a couple k7000s do the same thing.
The solution was jumpering the last two sync pins (-V and -H).
If the pins are already jumpered, then sometimes removing the jumper and connecting sync to -H only will solve it.
After the two pins are connected, if there is still an issue like this it can be adjusted out with the 50/60hz pot and the h-hold.
I can turn the V Pos, and V Size. Both work but have no relative effect on the problem.
The screen shrinks with the same portion at the top messed up.
I can move the screen up or down, but the graphics of the game are necessary in the affected area. This is a F1 Racing game, the MPH is in the upper left corner.
update:
I connected another Jamma to the monitor and it works fine, so I guess something is up with the jamma in the cabinet, maybe there is a setting or something, but
The monitor looks fine, the problem with the screen was with the PCB not the screen itself
I have a suspicion that the issue I have (similar to yours) is PCB and not monitor related. Hmmmmmmm
