WG 23" B&W monitor pic flipped
gameguy1957
Mobile, Alabama
I'm working on my Night Driver. The video was collapsed on the original chassis, but I had a spare one from a Boot Hill. All of the part numbers on the two chassis match up and swapping the chassis got a full picture, but it's upside down.
I hooked the yoke wires up just like they were when removed and have checked to see if anything is different on the chassis, but they look the same.
What wire need to be swapped to flip the picture? There are a red and green wire on the left side and a black wire on the right side (as looking at the back of the tube).
Thanks,
-JM
I got the wrong ID on the monitor, it's a Motorola and not a WG.
Still got the same problem with an inverted pic.
-JM
Problem solved thanks to a guy on google groups named Toyguy. He had the same problem back in 2003 with swapping a monitor from an Amazing Maze to a Sea Wolf.
There are two wires I missed on the chassis that go to the Vertical Output Transformer.
In Toyguy's post he said he noticed a grey and green wire swapped. They were both a dingy grey color on mine. I cleaned them and discovered just what he had found, they were swapped on the chassis from the mirrored game.
Changed it and now the picture is correct.
-JM
