WG 19v2000 XY monitor
NEGAMES
Red cloud, Nebraska
Hi every one I was wondering if someone can tell me where I can buy the contrast pot for A WG 19v2000 XY monitor. The monitor comes up with a picture real nice pic and starts to fade out until monitor is dark and it does this periodicly and I believe this is whats causing it.Let me know
Thank you
Thank you
Before you go replacing that, I would get some alligator clip multimeter leads and just clip 'em on the pot. Measure and record the resistance when cold, then power it up and compare when you start seeing your problem.
Also… Check your spotkiller LED when the image starts fading out. If it starts flickering on, you have a fault in the spot killer.
