zz0ljf
I need some trouble shooting advice. I have a WG 19K7915 where the red is over driven. It has a cracked neck board (85X0217B / P448) that I've since repaired all the the broken traces. Long story short the game got left on for an extended period due to my X10 truing itself on during a storm and after that the colors were fine but the picture was very fuzzy. I then recapped the monitor and now the red is over driven. The issue appears to be intermittent as at times the picture will go back to normal and I've been able to dial the monitor in nicely. I pulled the monitor today and reflowed all the traces on the neck board for the transistors (Q201 - Q203) and the color pots. I also reflowed the pins on the chassis for the monitor cable. Is it possible that one of the caps from my cap kit is causing the intermittent issue? That's the only other thing I can think of as the colors were fine before the cap kit. I've tried wiggling almost everything and I can't locate the cold solder join that way. Any advice is appreciated.
