I have a WG 19K7610 monitor (thick neck) have a question about the neck. Typically, with G07 and earlier WG monitors, there is a plastic "boot" that covers the end of the neck, including the glass tip, and protects the pins from moving. This 7610 monitor seems to have a black boot over the pins, but it doesn't cover the end of the protruding glass at the tip of the neck. Is that normal for a 19K7610 thick neck monitor?
While I have your attention, I also have a chassis for a K7000 thin neck that has an additional, small "box" sitting above the flyback and also has a wiring going to the anode. What is that?
Scott C.
Scott C.
