WG 19K7602 - Screen Invert
SP005
New Jersey
I just completed my first cap kit install. When I power it on, I see the screen itself in the proper horizontal orientation only the screen now reads right to left and not left to right. Did I flip one of the plugs by accident when installing the board?
If the monitor is mounted horizontally, find the red/blue yoke connector and turn it around.
If the monitor is mounted vertically, find the green/yellow connector and turn in around.
Thanks. When I reassembled it, I decided to go with matching the colors of the wires and not following which was pin 1. I also found this page which gives some more background on the problem:
http://www.homearcade.org/BBBB/yoke.html
Now I still have an issue with the monitor, the left side of the screen (mostly on the top) shows way too much yellow. I have tried all the adjustments and this is the best I can get it without compromising the rest of the colors. Pictures are attached. Before I did the cap kit it wasn't as noticeable as all the colors were washed out, now unfortunately it is obvious. Is there anything else I should try?
