WG 19K7201 cap polarity question
Yeah, could be a weak red gun in the tube.
Can you turn the red drive up and the contrast down a bit ?
(might have to turn the other color gains up a tad too with the contrast down)
Those three caps are bi-polar electrolytic caps.....10uf50V.....and I doubt they're your problem. I agree about rejuve time.
Edward
Some BP caps can cause color problems if they get too far out of tolerance...
Well the cap kit wasnt a complete loss, the picture does look a little sharper, but the color problems are still there. I have tried every setting imagineable.
I dont know anyone with a rejuvinator, but I do still have that old TV which would be good for a universal chassis, I wonder if there would be a compatibility issue with the touchscreen. Of course finding the proper mounting tape for the touchscreen could also be a problem, I suppose.
Post a pic of your picture. I assume you turned the contrast and brightness down to see if the bleeding stopped? As well as the drive and bias pots on the neckboard?
Ill get some pics up tomorrow. I've played with all the pots for literally half an hour, picture is basically tuned best I can get it at this point.
Video might be better for this one, reds are showing up better on camera than in person. First picture is with flash and the other 2 are no flash. This is the best possible picture I can get
